Calculate Field question
1514
08-23-2021 12:50 PM
CZU_MatthewMosher
I'm new to using Modelbuilder and Arcade expressions and am trying to automate some daily processes. I'm using the Calculate Field geoprocessing tool within modelbuilder to calculate the percentage of total acreage within a fire perimeter for each polygon. Currently, I am updating the total fire acreage in the model each day manually. Is it possible to pull the total acreage field from a feature class in separate geodatabase within the map frame automatically with Python or Arcade? In this case, I would want to pull the data from a geodatabase named "Event Group - All Layers", from a feature class named "Event Polygon", and from a field named "Acres".
I'm currently using the code below. The 725821.5 is what I would like to replace with a reference to the Event Polygon feature class.
$feature.Acres / 725821.5 * 100
If it's not possible to reference a separate geodatabase, it could also be done by dividing $feature.Acres by the sum of $feature.Acres, although I haven't been able to figure out how to do that.
Thanks for any help!
Matthew
Tim_McGinnes
There is a solution for calculating the sum of the field automatically using Python in this post: Field calculator, sum of field.
Tim_McGinnes
CZU_MatthewMosher
That works, thanks tim!
