Calculate - field is not nullable.
20834
12
03-31-2018 05:40 PM
JohnMorgan
I am working on a shapefile within ArcGIS Pro 2.1. I am trying to use the field calculator to add a few fields to the populated one I created. However, I keep getting the error message of field is not nullable.
Can anyone tell me what I am doing wrong?
Derek
DanPatterson_Retired
copy the geodatabase out to a new featureclass (Copy tool) with a totally different name
dump any unnecessary fields so that you just have the required fields (ie objectid, shape, shape_length, shape_area, shape_whatever ...)
do the calculation on a newly added field.
If that doesn't work.... start a new project... add just that featureclass and try again.
Report back since something is messed up an a clean reboot, restart with clean data is the only way you will track it down.
JohnMorgan
Hi, Dan.
I did finally get it to work after selecting Arcade as the Expression Type and selecting the Start editing check box. Go figure.
Thanks again for sticking w/ me on this one.
Derek
by Anonymous User
Not applicable
Out of curiosity:
Is ESRI willing to improve functionalities applicable on shape files? Easy operations like alter field name, change attribute ordering, make field nullable, etc, should be straightforward, no?
I have been ages waiting for this, so that importing and exporting to excel tables would finally be out of my daily business.
cheers
