calculate feild using phyton if function
2133
06-28-2021 09:00 AM
matu89
hello, i want to calculate feild using phyton if function to do the following :
if Height_Delta is greater than 0 write in the status cell " Uprise"
if Height_Delta is less than 0 write in the status cell "Downrise"
image is attached
can anyone can help with the code ?
thanks.
DanPatterson
MVP Esteemed Contributor
["Down_rise", "Up_rise"][!Height_Delta! > 0]
goes under Status =  line
not in the code block
some background
Fundamentals of field calculations—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
Height_Delta = 5  # ---- example value
["Down_rise", "Up_rise"][Height_Delta > 0]
'Up_rise'
Remember to put ! marks around Height_Delta ( !Height_Delta! ) since it is a python field calculator expression
matu89
can u tell where to write each line of the code in the feild calculator window ?
image is attached here :
 thank u
DanPatterson
some background
JayantaPoddar
Another alternative.
Expression:
Slope(!Height_Delta!)
Code Block:
def Slope(HT):
    if HT< 0:
        return 'Downrise'
    else:
        return 'Uprise'
Think Location
DanPatterson
expression
code_block(!Height_Delta!)
code block
def code_block(fld)
    """code block isn't really needed"""
    return ["Down_rise", "Up_rise"][fld > 0]
but as you can see it really isn't needed
