Calculate angle of polyline using field calculator?
2546
09-14-2022 03:16 PM
Labels (3)
avonmoos
Anyone have a code snippet I can use to accomplish this?
JohannesLindner
I'm currently answering a similar question here:
Re: How to calculate the angle of a line respect t... - Esri Community
Have a great day!
Johannes
DanLee
by Esri Regular Contributor
Calculate Geometry Attributes can calculate Line Bearing, if that's what you need.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-geometry-attribute...
DanPatterson
MVP Esteemed Contributor
JohannesLindner
Have a great day!
Johannes
avonmoos
This is what I ended up going with. Thanks!
// get a list of line parts
var paths = Geometry($feature).paths
// for each part, loop through each segment and get its angle (arithmetic angle -> East=0°, North=90°)
var angles = []
for(var p in paths) {
    var count_p = Count(paths[p])
    for(var q = 1; q < count_p; q ++) {
        var a = Angle(paths[p][q], paths[p][q-1])
        Push(angles, a)
// get the mean arithmetic angle
var arith_angle = Mean(angles)
// rotate so that North = 0°
var north_arith_angle = arith_angle - 180
return north_arith_angle + IIF(north_arith_angle < 0, 180, 0)
