buffer not working
12500
7
01-09-2020 01:27 PM
JonathanCollins1
So i have a group of XY data that i select in the buffer tool and put in 200 ft but when i hit the buffer button nothing happens. No buffers are drawn and the tool acts like nothing is happening. Any ideas?
Tags (1)
DanPatterson_Retired
Is it a featureclass? or just a table of data?
Does it have a defined coordinate system? and are the units in feet?
Perhaps some details or visuals.  Sounds like buffer doesn't like the input
MatthewDriscoll
Was the XY data just created?  If so you will probably need to save your edits before running the tool.  Also I find I need to sometimes simply close and reopen to get a tool to work after I had been doing a lot of different things in Pro.
JonathanCollins1
as far as i can tell it has coordinates. Its a feature class built from XY data table.
Scott_Harris
Hi Jonathan,
From your screenshot, it doesn't look like you have a feature template to work with. Do you have an editable feature class in your map (lines or polygons)? When you do, try choosing the one of their templates in the drop-down in the Buffer tool.
-Scott
JonathanCollins1
saving does not help pushing the buffer button at the bottom does nothing like before. I really wish if there was an error it was displayed. I get no feedback as if I have pressed nothing.
Try Buffer in Analysis
Buffer—Help | ArcGIS Desktop
JonathanCollins1
genius, thank you
