Batch convert .las files to .slpk
10839
13
04-20-2021 11:27 PM
ValerieMFoley
I cannot seem to figure out a way to batch convert several LAS files to the SLPK file type. I have tried both creating a model using model builder but the 'Create Point Cloud Scene Layer Package' tool and the 'Iterate Files' iterator, but the tool will not accept the input of the files from the iterator (reference 'Model' images below). I have also tried to create a python script and run it using the notebooks option in ArcGIS Pro and am able to have multiple .las files convert into a single .slpk file but I cannot get the script to output a single .slpk for each .las (reference 'Script_error' image below). Any help would be great, I have exhausted my online resources.
Script of multiple .las to a single .slpk:
import arcpy
import os
from arcpy import env
wksp = env.workspace = "C:\LiDARTest"
inpath = "C:\LiDARTest\InFile"
outpath = "C:\LiDARTest\OutFile"
Output_Coordinate_System="PROJCS['NAD_1983_2011_StatePlane_Illinois_East_FIPS_1201_Ft_US',GEOGCS['GCS_NAD_1983_2011',DATUM['D_NAD_1983_2011',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',984250.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-88.33333333333333],PARAMETER['Scale_Factor',0.999975],PARAMETER['Latitude_Of_Origin',36.66666666666666],UNIT['Foot_US',0.3048006096012192]];-17463800 -46132600 3048.00609601219;-100000 3048.00609601219;-100000 10000;3.28083333333333E-03;3.28083333333333E-03;0.001;IsHighPrecision"
arcpy.management.CreatePointCloudSceneLayerPackage(in_dataset=inpath, out_slpk=outpath, out_coor_system=Output_Coordinate_System, transform_method=[], attributes=["INTENSITY", "RGB", "CLASS_CODE", "FLAGS", "RETURNS"], xy_max_error_m=0.01, z_max_error_m=0.01, in_coor_system="", scene_layer_version="2.x")
Script of multiple .las to multiple .slpk:
import arcpy
import os
rootdir = "C:\LiDARTest\InFile"
name = 0
for subdirs, dirs, files in os.walk(rootdir):
     for file in files:
          output_layer = "C:\\LiDARTest\\OutFile\\" + str(name)
          arcpy.management.CreatePointCloudSceneLayerPackage(in_dataset=file, out_slpk=output_layer, out_coor_system=Output_Coordinate_System, transform_method=[], attributes=["INTENSITY", "RGB", "CLASS_CODE", "FLAGS", "RETURNS"], xy_max_error_m=0.01, z_max_error_m=0.01, in_coor_system="", scene_layer_version="2.x")
          name = name+1
*ignore my naming convention have not taken the time to work on that part of the script
Andrew--Johnson
Hi
Yes, that's probably best at this point 🙂 I'm not sure what time zone you are in but i'm in the pacific time zone. My morning tomorrow is full of meetings but after 12pm i'm free and I can send you a zoom link. Let me know what works for you.
thanks,
Andrew
TimFarrier
Hi Andrew,  As an alternate approach - did I see something during the User Conference 2021 on being able to use pdal to convert from las to i3s/pcsl?  Is that right or am I making things up?  If I did would you please direct me to those materials.  Thanks Tim
Andrew--Johnson
Hi Tim,
Sorry i'm not familiar with that. I see pdal has a i3s reader https://pdal.io/stages/readers.i3s.html but that's all the information I have.
thanks,
Andrew
TimFarrier
Thanks Andrew,  I could be that I wasn't paying full attention and that the conversation was about i3s to las and not the other way around
