Basic Census Join Problem
1576
04-10-2025 07:50 PM
EthanGlaudemans
I'm trying to join a census block shapefile, taken from here, with a census data table found here. The problem is the attribute tables don't align, in particular their GEOIDs. I've got no idea what to do, is it a problem with my data sources? Pictured below are the two hyperlinks, as well as the attribute tables from my two sources of data.
Tags (3)
DanPatterson
MVP Esteemed Contributor
If one file from Alabama and one from Texas?  If so, you can't perform a "join" perhaps a "merge".
Join is used to associate attributes to a base file for an area
Add Join (Data Management)—ArcGIS Pro | Documentation
Merge combines things spatially
Merge (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
EthanGlaudemans
Hi Dan, thanks for the reply. I'm only using the 2020 shapefile, so just downloading the Texas blocks. A merge wouldn't work as the data I'm pulling from the census is only a table, so I need to use the GEOID to match the rows of data with the corresponding census block in the shapefile data. If you wanted to give it a try it should be easy to reach where I am, I'm thinking I'm just using the wrong data somehow but I'm not sure where else to get a shapefile for Dallas census blocks.
DanPatterson
not sure what is going on, but what I saw in your image was data from two separate geographic areas, which obviously isnt going to work
EthanGlaudemans
Definitely not, the census blocks I downloaded are for all of Texas while the census data is for Dallas County, so my idea was to clean the data if needed then do a join for the two so just the census blocks from dallas county would be joined + exported as a new file.
DavidPike
MVP Notable Contributor
If there's no common field to match to or a logical way to create a common field e.g.
table 1 - GEOID000567
table 2 - 567
-> Create new calculated field for table 2 and then match against -> 'GEOID000' + [table2]
Other than manually adding a matching attribute then joining - you'll need to find a new polygon data source.  I would imagine there's many alternatives.
