Basic Census Join Problem
1590
5
04-10-2025 07:50 PM
EthanGlaudemans
I'm trying to join a census block shapefile, taken from here, with a census data table found here. The problem is the attribute tables don't align, in particular their GEOIDs. I've got no idea what to do, is it a problem with my data sources? Pictured below are the two hyperlinks, as well as the attribute tables from my two sources of data.
EthanGlaudemans_2-1744339729603.pngEthanGlaudemans_2-1744339729603.pngEthanGlaudemans_3-1744339749740.pngEthanGlaudemans_3-1744339749740.png
Tags (3)
DanPatterson
If one file from Alabama and one from Texas?  If so, you can't perform a "join" perhaps a "merge".
Join is used to associate attributes to a base file for an area
Add Join (Data Management)—ArcGIS Pro | Documentation
Merge combines things spatially
Merge (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
EthanGlaudemans
Hi Dan, thanks for the reply. I'm only using the 2020 shapefile, so just downloading the Texas blocks. A merge wouldn't work as the data I'm pulling from the census is only a table, so I need to use the GEOID to match the rows of data with the corresponding census block in the shapefile data. If you wanted to give it a try it should be easy to reach where I am, I'm thinking I'm just using the wrong data somehow but I'm not sure where else to get a shapefile for Dallas census blocks.
DanPatterson
not sure what is going on, but what I saw in your image was data from two separate geographic areas, which obviously isnt going to work
EthanGlaudemans
Definitely not, the census blocks I downloaded are for all of Texas while the census data is for Dallas County, so my idea was to clean the data if needed then do a join for the two so just the census blocks from dallas county would be joined + exported as a new file.
DavidPike
MVP Notable Contributor
If there's no common field to match to or a logical way to create a common field e.g.
table 1 - GEOID000567
table 2 - 567
-> Create new calculated field for table 2 and then match against -> 'GEOID000' + [table2]
Other than manually adding a matching attribute then joining - you'll need to find a new polygon data source.  I would imagine there's many alternatives.
