Automatically create polygons across multiples points on a map and Summarize within each polygon.
2754
12-06-2022 08:04 AM
Labels (2)
AbishekDeiveekan
Hello there,
So I have 3 layers
250 datapoitns with Cordinates
Circle I need to draw
US Census Tract layer ( I need to use this layer for this particular analysis)
My objective is draw a circel of say 100km radius around each of these points and summarize the population of all the census tracts that are under it.
Current solutuon: Insert tab - Distance and direction, then I manually have to draw a circle with a center point. Then I can summarize within the Circle I drew and the Cencus Tract layer.
Since I have to do this manually for 250 points, I was wondering if there was a way to automate atleast parts of this.
Like drawing the ciccles automatically using the Datapoints as centers.
DanLee
by Esri Regular Contributor
Use the Buffer tool on your points with 100km as the buffer distance. That should give you the circles.
Then use Apportion Polygons on the buffer polygons and census tracks to get the summarized population.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/apportion-polygon.htm
DanLee
AbishekDeiveekan
This worked perfectly exactly what I wanted. Thank You
DanLee
You are welcome.  I am glad it worked for you.  Happy geoprocessing  🙂
