AttributeError: module 'time' has no attribute 'clock'
4863
07-18-2022 03:05 PM
NatureTrust
I am trying to run an external tool, Linkage Mapper, and receive the following error:
Python error on **line 129** of s1_getAdjacencies.py in Linkage Mapper Version 3.0.0:
It seems this is a Python issue, but I do not know how to correct it. Can anyone direct me to the correct resources?
DanPatterson
MVP Esteemed Contributor
clock ... deprecated in python 3.3, removed in 3.8
time.clock() removed in Python3.8 replace with time.perf_counter() · Issue #1510 · wxWidgets/Phoenix...
Pro uses python 3.9, so replacement is time.time()
... sort of retired...
NatureTrust
Would this then be an issue with the external tool, Linkage Mapper?
DanPatterson
No clue, but if Linkage Mapper is using python and its version is < 3.3, then yes
