AttributeError: module 'arcpy' has no attribute 'ExportDataChangeMessage_management'
5016
08-18-2022 12:05 PM
Labels (3)
DanielCarvalhoCosta
Hello community! I'm needing to use the following arcgis pro functionality in my python script: https://pro.arcgis.com/en/pro-app/2.9/tool-reference/data-management/export-data-change-message.htm
When calling the function in my code, the following message appears:
Remembering that I'm importing arcpy.
DanPatterson
you have a standard or advanced license?
Export Data Change Message (Data Management)—ArcGIS Pro | Documentation
if so, on a lark try it as
arcpy.management.ExportDataChangeMessage(....
... sort of retired...
Luke_Pinner
MVP Regular Contributor
What version of ArcGIS Pro are you using?  That tool is only available in 2.9 or 3.0 (or ArcGIS Desktop, it looks like it was one of the tools that didn't make it into Pro initially)
