Attribute table fields constantly changing appearance?
3190
07-02-2021 12:34 PM
KeithJ
Recently, my fields in Pro starting changing width after queries.  My attribute tables became justified and I'm hoping there is a way to change them back that I haven't found online.  I do some data entry and having to scroll to the end of a table is extremely frustrating.  I usually shrink the fields so that I can see the entire table on one monitor.
This is just a very simple example, but all the fields expand in appearance after running a query.  Here's a simple example:
State field prior to a query:
State field after query:
If anyone knows how to set these field lengths permanently please let me know.
Scott_McGee
I'm having the same problem with the widths of the columns (fields) in my attribute table changing unexpectedly. This started occuring after I upgraded Pro to version 2.8.2. I have noticed this behavior under these situations:
  • Calculate a field value (doesn't matter which field)
  • Stop the edit session
Here are screenshots that illustrate the changing column (field) widths under the above situations:
Before
After
This behavior affects any attribute table that I have the focus on. It is really annoying, as I have to constantly resize the widths of the columns to get them back to my optimal view. It really seems like a bug in the software.
Can anyone else replicate this behavior?
KennethElsner
A case has been opened with Esri TS. #02883364
KeithJ
Thanks Kenneth!
JillHalchin
Attribute tables jumping to different records, fields resizing, etc. was a major problem until a few versions ago (don't remember which).   I remember all of the problems were finally fixed by an update in 2020, maybe 2.5.2.  It was a major reason I didn't use Pro on a regular basis until that update.  Really disappointing to see this is back.
Bud
Legendary Contributor
Esri Case #03730900 - Column width behavior is inconsistent
BUG-000171080: In ArcGIS Pro, when resizing a column in the attribute table by double-clicking on the boundary between two columns, the resize does not stay after refreshing the table.
Workaround: Resize the right-sided edge of the column by dragging it. When resizing this way, the column width will stay the same after refreshing the table.
Status: New
Annoying resizing of Columns in attribute table
