attribute rules acts not as expected
897
09-06-2020 09:11 PM
OrrGvili
Hi
I have attribute rule to update field based on other field value and  values from tables,
its working ok when i edit the GrowthName field
but i try to edit the field the rules applied (Growth Code) when i apply the change the value change back to null
even if the GrowthName is  null
and i cant figure out why
var Growth = $feature.GrowthName
var GrowthList = FeatureSetByName($datastore,"GrowthCodeTable",["Code","Name"])
if (Growth != null ){
    var sql = "Name = @Growth ";
    var filterGrowth = Filter(GrowthList, sql)
    var GrowthCode =  First(filterGrowth).Code
    return GrowthCode
by Anonymous User
Not applicable
HiOrr Gvili Madhav GavkadkarRobert Instrall
It seems you have not configured the attribute rule on the field "Growth Code" for edit operation of Update.
Regards,
Manoj
