Attribute Rule: Unexpected Null error when parsing dictionary
320
03-25-2026 05:42 AM
Labels (2)
Radnod
I have trouble validating an attribute rule using a dictionary as source (using ArcGIS Pro 3.2.1).
My input is a JSON string (generated by another rule with priority 1):
{"Dataset1":[], "Dataset2": ["text", "more text"]}
I am using this expression to parse the JSON:
var out = null;
var dataset = "Dataset2";
var dict = FromJSON(Text($feature.json));
var arr = dict[dataset];
if (IIf(DefaultValue(arr, 0) == 0, false, true)) {
  out = Concatenate(arr, ", ");
return out
Using the expression in a popup works, as attribute rule the validation always fails at line 5:
Arcade Error, unexpected null
It seems like the dictionary isn't parsed properly as long as I try to use it in an attribute rule.
Returning the dictionary as out works, the validation then complains about dict not being a string.
Returning out = Text(dict) returns the initial JSON string.
What am I doing wrong here?
Robert_LeClair
Esri Esteemed Contributor
In reviewing this item, I found that this expression might work better:
var out = null;
// Parse JSON safely
if (IsEmpty(dict)) {
return null;
// Check if key exists
if (!HasKey(dict, dataset)) {
return null;
// Ensure it's a valid array with values
if (!IsEmpty(arr) && Count(arr) > 0) {
return out;
Why this works better is the HasKey() prevents invalid dictionary access, the IsEmpty avoids null dereferencing, the Count() ensures you're not concatenating an empty array and it removes the DefaultValue(arr, 0) logic which is not reliable for arrays.  I don't have the data to test but think it will work.
