attribute rule attachment table: expected attachment type arcade error
1014
01-15-2024 07:29 AM
geopamplona
Hi
I am using arcade code to count attachments and save in field, but
Count(Attachments(item));
but I get the following error:
invalid arcade expression, arcade error: expected attachment type, script line: 4geopamplona_0-1705332358982.png
I'm using ArCGIS pro 2.9.11 and enterprise 2.9.1
My attribute rule:
var features = FeatureSetByName($datastore,'FeatureClass', ['*'], false);
var gid=$feature.REL_GLOBALID;
var item=First(Filter(features, 'globalid = @gid'));
var count = Count(Attachments(item));
if ($editcontext.editType == 'DELETE'){
var count_total=count-1
} else {
return {
'edit': [{
'classname' : 'FeatureClass',
'updates' : [{
'globalid': gid,
'attributes' : {'Adjs' :count_total }
I have tried the same Count(Attachments()) line and it is valid arcade for calculated fields.
Thanks!
CodyPatterson
MVP Regular Contributor
Hey @geopamplona
I found a post from a while back that somewhat matches what you have: https://community.esri.com/t5/arcgis-online-questions/arcade-count-attachments-in-related-table/td-p...
I was curious if you could try to do:
    var cnt = 0
    for(var item in features) {
        cnt += Count(Attachments(item))
    var count_total=cnt-1
    } else {
    var count_total=cnt
    return {
    'edit': [{
    'updates' : [{
    'globalid': gid,
This is just a rough rendition so I hope it can provide some help!
Cody
