Attribute Assistant vs Attribute Rules ArcGIS Pro
3010
08-16-2021 08:02 PM
MarlaJohnson
If you are using traditional versioning can you use Attribute Rules?  If not can yo use attribute assistant in ArcGIS Pro?  If so where can I locate the documentation.
DavinWalker2
Yes you can use attribute rules if you are using traditional versioning with a one exception.
  • Batch calculation and validation rules in an enterprise geodatabase are evaluated using the validation server for datasets that are branch versioned. To add these rule types, the database connection must have Versioning Type set to Branch.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-attribute-rule.htm
MarlaJohnson
Do you know if you can use the attribute assistant in ArcGIS Pro?
DavinWalker2
Hi Marla,
No, attribute rules are the replacement for this functionality in ArcGIS Pro.
MatthewStull1
I saw this thread and wanted a little more clarification if you can provide it?
We want to use traditional versioning with attribute rules in Pro.  It sounds like we can use all the rules, we just can't use them in a batch mode (with branch versioning- feature services and Portal/AGOL).  Meaning that any Calculation or Validation rules we have in our Enterprise Geodatabase data get processed immediately and not at some later user-specified time, correct?  Is that the only difference between traditional and branch versioning with attribute rules in Pro?   We really want to move to use Pro instead of the Attribute Assistant in ArcMap.  Thanks for your help!
