Assign Elevation Line from DEM
1413
02-27-2024 08:42 AM
StasiaPietraszun
I am trying to create a line on a color gradient using DEM. We are trying to show elevation differences across levees and were going to use elevation points for color gradient, but we want to see if it's possible to make a line color gradient instead of points. I am currently using ArcGIS Pro 3.2.1.
Ed_
by MVP Regular Contributor
Good morning @StasiaPietraszun, when you say line? do you mean contours?
Question | Analyze | Visualize
StasiaPietraszun
I've never used contours yet, but from what I do know about them, they show more vertices to indicate elevation or whatever you want them to measure? We are hoping to get a flat, 2d representation of elevation across a line tool, and assign DEM to the line to create a color gradient. I'm not sure if this is possible? I did some research already but had a hard time finding anything, so I thought I would check on here before moving forward.
Ed_
Hi @StasiaPietraszun, thank you for providing the additional info so I think Create contour lines in ArcGIS Pro, can help you.
Since you have a DEM raster I would look under the Use the Contour Function section.
Once the contour lines have been created, you can symbolize (apply color gradient) them using the elevation (Z) attribute.
StasiaPietraszun
I will try this out. Thank you!!
