Assemble adjacent parcels together based on size
806
12-11-2024 01:48 PM
MiaLogg
I'm trying to find potential parcels that can accommodate a facility site. The parcels need to be a certain size (e.g. 10 acres) for the facility. However, we have the option to assemble adjacent parcels together for the facility site. Is there a process within ArcGIS Pro that can identify groups of parcels that can be assembled to reach the needed size?
DanPatterson
MVP Esteemed Contributor
Solved: Selecting adjacent polygons with the same attribut... - Esri Community
you will have to add a field to your table based on whether the size is >= 10 acres, (eg Y or N in a text field with a field calculation), then follow the above
... sort of retired...
