ASCII to feature class error code 999999
1190
07-20-2023 07:37 AM
JustinChute
I am trying to use a significantly large amount of .laz files to create a terrain dataset to use to then make a DEM. I am doing the following
1. ASCII 3D data: all of my LAZ files
2. File format: XYZ
3. Output feature Class: is in a geodatabase and then within a feature class (Also tried without feature class)
4. Output Feature Class Type: Multipoint (This is for an entire states county)
5. Z factor: 1
6. Coordinate System: set to what I am using
7. Average point spacing: 1
8. File Suffix: N/A
9. Decimal separator: Point
With all of this and trying a few more odds and ends, I am still receiving the 999999 error code.
Robert_LeClair
Esri Esteemed Contributor
@JustinChute - perhaps an odd question, but by chance do you have the German language pack installed on your computer?  This has caused the 999999 code in the past.
JustinChute
I do not have that installed.
