Artifacting in layout view
822
08-23-2023 02:10 PM
BryanMaas
I'm having an issue of large triangles and lines appearing appearing in my background map when I switch to layout view (see attached images).  They also appear on any PDF or print I make.  I've tried updating my graphics drivers, switching back and forth from DirectX to OpenGL.  I do not believe it matters but I do have three map frames on my project.    I'm working in ArcGIS Pro 2.4.0
Map view
layout view
JeremyWright
Hi Bryan,
This looks like an issue with the geometries of vector tiles drawing inconsistently (flyaways/some of the vertices are in teh wrong place).
I noticed you are on an officially RETIRED build of ArcGIS Pro.  Please update to a currently supported build and if the issue is still reproducible we will need more specifics about what draws this way (is it all layers?  All basemaps only?) and perhaps a repro mpkx if possible.
Regards,
Jeremy W.
EDIT: here's the table showing supported versions of ArcGIS Pro and their lifecycles: https://support.esri.com/en-us/products/arcgis-pro/life-cycle
