Area and buffer calculations
1928
01-14-2024 03:41 AM
NathanHotti
I have created a 300m buffer for all the polygon's on my map but need to refine my data to only show or represent polygons/shapes with an area of 2 hectares or greater and then find the population living within 300m of each shape. How would I go about doing this. (I have a table of contents for the buffer that I have joined with the population data).
RonaldHaug
Hi Nathan,
I think you will have to start over and use these steps:
1) If there is any doubt in your mind about the area of your polygons, calculate geometry in the area attribute field.
2) Select by attribute polygons with area >= 2 ha.
3) Buffer polygon selection to 300 m.
4) Intesect population with polygon buffer.
5) Count population in each polygon buffer.
6) You could make a Feature to Excel table or a table from the Intersect feature.
That's about it. Go forth and prosper.
Items in italics are tools. You can search for them in the rectangular box at the top center of your ArcGIS Pro screen.
