Are tables in the same EGDB, but accessed from different .sde connections, considered in the same workspace?
627
05-06-2024 02:36 AM
Bud
Legendary Contributor
ArcGIS Pro 2.9.5; Oracle 18c 10.7.1 eGDB:
I have two standalone tables stored in the same owner/user/schema (ENGINEERING) in the same enterprise geodatabase:
  1. ENGINEERING.Table_A, added to the map via a database .sde connection, connected to the Oracle ENGINEERING owner/user/schema.
  2. ENGINEERING.Table_B, added to the map via an OS Authentication .sde connection.
A question about joins:
Add Join (Data Management)
A one-to-first join is also only possible if each table is from a different workspace.
From an Add Join perspective, are the the two tables considered to be in the same workspace, even though they’ve been accessed via different .sde connections?
