Are contingent values supported in AGOL (publishing from ArcGIS Pro)?
1428
06-13-2019 06:18 AM
AndyEvans
I'm using ArcGIS Pro v2.3 to try and publish a web layer containing contingent values to AGOL. Layer publishes successfully, but does not seem to carry over any contingent value information when consuming in AGOL and Collector. I thought I read an article somewhere that described support for this, but I can't seem to find it at the moment. Has anyone had any success with this?
KoryKramer
Esri Community Moderator
My guess is that it just isn't supported in ArcGIS Online (yet?).  Perhaps somebody in the ArcGIS Online‌ space can confirm/comment.
by Anonymous User
Not applicable
I know this is an old thread, but I have the same question.  I publish a hosted feature service from a file gdb that has contingent values set (verified in Pro when using the File GDB can create feature and it sees the contingent values) and I can see contingent values mentioned in the hosted feature service but when I bring the hosted feature service into ArcGIS Pro or an app built off of ESRI Runtime SDK for Android (100.13)  the contingent values are not recognized.  Wondering what gives?
Going to the actual layer itself I also see confirmation...
Code used in Runtime..field group list returns 0.  Note that verified on download from feature service contingent values are enabled.
ContingentValuesDefinition cvD = activeGdbFeatureTable.getContingentValuesDefinition();
cvD.loadAsync();
cvD.addDoneLoadingListener(() -> {
if (cvD.getLoadStatus() == LoadStatus.LOADED) {
List<FieldGroup> fG = cvD.getFieldGroups();
Log.e("WTFF", String.valueOf(fG.size()));
