Are Arcade geometry subtypes immutable? (i.e. point, polyline, polygon)
4123
7
03-02-2022 10:42 PM
Bud
Legendary Contributor
If I understand correctly, the Arcade Geometry type has subtypes:
  • Point
  • Multipoint
  • Polyline
  • Polygon
  • Extent
Question:
Are those subtypes immutable, since the Geometry supertype is immutable?
Geometry is immutable, meaning it is not possible to change the geometry after it is created.
For example, if I assign a value to a point, does that mean that geometry can't be changed?
var pt = Point({ 'x': 100, 'y': 100, 'spatialReference':{'wkid':102100} });
JohannesLindner
In my experience, yes.
For example, you can't do something like this:
Console(pt)
// attempt to change x coordinate
// this will fail
pt.x += 5
Console(pt)
"Immutable" just means "This object and its values can not be changed".
To work around it, you have to make a copy of the geometry's values, change them and then create a new geometry with these changed values:
Console(pt)
//pt.x += 5
var new_pt = Point({'x': pt.x + 5, 'y': pt.y, 'spatialReference': pt.spatialReference})
Console(new_pt)
// you could also extract the geometry's dictionary and change the values there:
var pt_dict = Dictionary(Text(pt))
pt_dict.y += 5
var new_pt_2 = Point(pt_dict)
Console(new_pt_2)
To change the geometry of polylines or polygons, you have to take it a step further: you have to recreate the paths/rings.
var old_path = Geometry($feature).paths[0]
var sr = Geometry($feature).spatialReference
var new_path = []
for(var i in old_path) {
    // move vertext to north east and remove digits, because why not?
    var new_vert = Point({'x': Round(old_path[i].x) + 100, 'y': Round(old_path[i].y) + 100, 'spatialReference': sr})
    Push(new_path, new_vert)
var new_geo = Polyline({'paths': [new_path], 'spatialReference': sr})
Console(Geometry($feature))
Console(new_geo)
Have a great day!
Johannes
JohannesLindner
Console(pt)
// this will fail
pt.x += 5
Console(pt)
Console(pt)
//pt.x += 5
Console(new_pt)
pt_dict.y += 5
Console(new_pt_2)
var new_path = []
Console(new_geo)
Have a great day!
Johannes
jcarlson
For simple adjustments, you can also convert the original geometry to a dictionary and manipulate it.
var pt = Point({
    x: 40,
    y: 12,
    spatialReference: {
        wkid: 102100
var pt_json = Dictionary(Text(pt))
pt_json['x'] = 20
// returns 20
return Point(pt_json)['x']
If you wanted, you could even develop your own custom functions around this idea:
function Translate(in_point, x_shift, y_shift){
    var pt_json = Dictionary(Text(in_point))
    pt_json['x'] += x_shift
    pt_json['y'] += y_shift
var test_point = Point({x: 40, y: 12, spatialReference: {wkid: 102100}})
return Translate(test_point, -10, 5)
But that doesn't change the answer that no, you can't manipulate geometry objects in place, only while converting to another object, or overwriting the entire variable with a new object.
- Josh Carlson
Kendall County GIS
Bud
Side question:
In your post, it looks like you are sending an output to the console().
Out of curiosity, what are you doing there? Where are you displaying that value?
Thanks.
jcarlson
The console is more for debugging or checking on things. Useful for longer, more complex expressions, but you can only see those messages in the Expression Builder interface, such as in AGOL.
When you test an expression, you can see there are the results and the messages.
- Josh Carlson
Kendall County GIS
JohannesLindner
I recently learned that you can also see them in Pro:
Verify the expression, then you can click on the button.
Have a great day!
Johannes
jcarlson
- Josh Carlson
Kendall County GIS
Bud
I found this post just now, which confirms what @JohannesLindner mentioned.
Where do the Arcade Console messages go to?
