Arcpy writes a shapefile with wrong coordinates
1986
02-25-2021 06:15 AM
OlesiaIgnateva
Hello!
I want to write a polygon shapefile from a dictionary with vertices coordinates using arcpy, here is my code:
def _getShp (inFC, outFC, vertices):
# this is the method using arcpy
# Create a new polygon feature class using coordinates.
# Each coordinate entry is in the format of {ID: [(X1,Y1), (X2,Y2)....]}
cur = None
try:
    # Create the output feature class
    arcpy.CreateFeatureclass_management(os.path.dirname(outFC),
    os.path.basename(outFC),
    "POLYGON")
    # Access spatial reference of template to define spatial
    # reference of geometries
    spatial_reference = arcpy.Describe(inFC).spatialReference
    # Open an insert cursor for the new feature class
    cur = arcpy.da.InsertCursor(outFC, ["SHAPE@"])
    # Create an array object needed to create features
    # Initialize a variable for keeping track of a feature's ID.
    # ID = -1
    for fid in range(len(vertices.keys())):
        array = arcpy.Array()
        # Add the point to the feature's array of points
        # If the ID has changed, create a new feature
        for i in range(len(vertices[fid])):
            array.add(arcpy.Point(vertices[fid][i][0], vertices[fid][i][1],  ID=fid))
        polygon = arcpy.Polygon(array, spatial_reference)
        cur.insertRow([polygon])
except Exception as e:
    print(e)
finally:
# Clean up the cursor if necessary
    if cur:
       del cur
The problem is that it writes my file wrong. Instead of positive number of X coordinate it writes a negative number, while the Y coordinate stays the same, e.g. the coordinates were around +381462 and became -367560. The coordinate system is WGS 39N. In the end I have got a wrong location. What's wrong could be in the code? Please find a screenshots in attached, but don't look at the polygons' shape, it is another problem I am aware of it 🙂
DavidPike
MVP Notable Contributor
not too sure, can you try assigning the spatial reference with an EPSG code rather than a template?
also in:
I guess it should be "ID" not ID (which you have as a variable set to -1 - also not sure what that ID of -1 is meant to be doing).
Finally please use the code formatting available to make it readable, all the indents are gone in what you've posted.
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - GeoNet, The Esri Community is the link for formatting
... sort of retired...
OlesiaIgnateva
Thank you very much! 🙂
