arcpy 3.2 - DLL load failed while importing _arcgisscripting
3958
08-13-2024 03:04 AM
padmalcom
Hi, we try to use the python api for ArcGIS Pro 3.2. Unfortunately, we meet an error when importing arcpy.
What we do is to create an anaconda environment and install arcpy:
conda create -n arcgisexporter python=3.9
conda install arcpy=3.2 -c esri
When executing a python file in this repository with just the line "import arcpy",  I get a the following error:
ImportError: DLL load failed while importing _arcgisscripting: The specified module could not be found.
ArcGIS Enterprise 3.2.2 is installed on the same machine and running.
padmalcom
Okay, I got it working by first installing arcgis and then arcpy-base.
DanPatterson
MVP Esteemed Contributor
install arcpy-base which provides the minimum requirements for arcpy
... sort of retired...
DanPatterson
Install ArcPy—ArcGIS Pro | Documentation
the link from the help
padmalcom
Thank you @DanPatterson, but the error remains the same even when I install arcpy-base.
Could it be the case that I am not allowed to install arcpy in an empty conda environment that is not based on the arcgispro-py3 environment that comes with the conda installation of ArcGIS Pro?
padmalcom
