ArcPro Solution not working with new update
569
02-20-2025 10:06 AM
JillRobson
The Fire Accreditation Solution for ArcPro is not available with the 3.4.0 update. The solution is "read only" and I have no way of using it nor can i contact ESRI directly about it. Does this happen for every solution when there is an update, and is there an expected time when Solutions are useable with newer versions? I need this for an Accreditation project with a Fire Department and I can't access it when i should be able to, so it would be nice to know if i am going to be able to use this in the future
Robert_LeClair
Esri Esteemed Contributor
There was a new version (2.1) of the Fire Accreditation Analysis solution on November 2024 released.  You can find it here - Introduction to Fire Accreditation Analysis—ArcGIS Solutions | Documentation
I'd recommend downloading and deploying the 2.1 version and see if that works for you.
