ArcPro Not Loading
785
12-14-2023 03:37 AM
StephenKasacek
A coworker recently renamed a high level folder which contains all our project folders, which in turn is where all our data lives. Since that happened ArcPro refuses to load any project files. I thought it was due to all the links changing since the highest level folder changed, so I renamed it but am still experiencing the slow/no load.
I ran a test and created a plain map and it worked fine, which seems to me more proof it's an issue with the renaming. No other changes were made, I am running 3.2 and have been for a bit.
I am very worried all of my work is gone now, of course the data files aren't deleted but the project files are so corrupt they won't load so I'll have to start from scratch. Even our template, which is under that larger file which was renamed, does not load.
To make matters worse (I think) my organization uses DropBox for file storage and Carbonite to backup files, so I think I have two apps trying to sync massive amounts of data due to the name changes. Even when it appears everything is sync'd up ArcPro still doesn't load projects.
