ArcPro Log File Location
13215
06-03-2022 04:15 PM
KChevy
I have ArcPro 2.9.3 installed and would like to know where the log file for Pro would be located.  I've looked in \AppData\Local\ESRI\ErrorReports but they are dmp files which don't have software to view it. Can someone share where to find the log file so I can view.
Thank you in advance.
Keith C.
DanPatterson
MVP Esteemed Contributor
depends where you have set log files?
and history is located in the "roaming" section of your profile
... sort of retired...
Hannes_Brandt
More information on the "geoprocessing options" metioned by @DanPatterson can be found here in the "Logging" section:
https://pro.arcgis.com/en/pro-app/2.9/help/analysis/geoprocessing/basics/geoprocessing-options.htm
There is also a new tool since version 2.9 called "Diagnostic Monitor" which can be started directly out of ArcGIS PRO (Ctrl+Alt+M) and also has a section "Log".
https://pro.arcgis.com/en/pro-app/2.9/get-started/arcgis-diagnostic-monitor.htm
