ArcPro legend layer transparency
9175
12
02-07-2018 06:02 AM
NigelBerjak
Is there a way to turn off the simulated symbol transparency in the legend? In ArcMap it is done simply via the dataframe properties via the 'Simulate layer transparency in legend' checkbox, but I've looked everywhere and I cannot locate it in ArcPro.
Nigel
Steve_Moore76
Man... I agree with the posts. I'm really trying to use Pro, but it results in a lot of "banging my head against the wall" to find solutions. I spend a LOT of time hunting around for equivalent options we used to have in ArcMap. Many options in ArcMap were not perhaps very elegant, but they worked pretty consistently. I want that option for layer transparency in the map, but not in the legend patches because I'm using a colored background there and the transparent patches look bad. I'm going to have to resort to some awkward, time-consuming graphic workaround or completely convert my legend to graphics.
NigelBerjak
A workaround is that if you have an image, or non-transparent base layer, you can make a 'legend' set of layers below this, with no-transparency. You keep all of these on and because they are below the base layer, they will not display on-layout. They can then be added to and display without transparency in the legend. Not an ideal, but at least the legend then maintains its link to the main map without having to convert to graphics etc, which I have never found overly useful.
Hope this helps.
KFAgis1
I was going to submit a "New" Idea but figured I'd just tack onto this. . . .again. . . 2 years later. Esri Dev Team, can we Please bring back the "Simulate Layer Transparency" option? The 'ol, "if it ain't broke, don't fix it" moto. I often use layer clipping/duplication etc. and DON'T want the legend to reflect the lighter, washed out layer BUT the clipped layer may not contain all features. Why was this omitted and still not reintegrated under the Map Frame (OR MORE LOGICALLY) Legend Properties? Thank you!
