ArcPro legend layer transparency
9179
12
02-07-2018 06:02 AM
NigelBerjak
Is there a way to turn off the simulated symbol transparency in the legend? In ArcMap it is done simply via the dataframe properties via the 'Simulate layer transparency in legend' checkbox, but I've looked everywhere and I cannot locate it in ArcPro.
Nigel
AdrianWelsh
MVP Honored Contributor
Nigel,
I'm not sure if this is the same thing as what you are looking for but, go into the Color Properties of the symbol and you can adjust the transparency in there:
NigelBerjak
Hi Adrian
Thanks for your response. No, I can style each symbol by its transparency and the layers, but in the legend the symbols for the layers are also transparented based upon the layer. I want to keep the transparency on the map but not have it transparent in the legend. Does that help to clarify things?
Nigel
AdrianWelsh
That does make more sense. Take a look at this thread that mentions this topic. I think it can help:
https://community.esri.com/thread/164095
AdrianWelsh
oh, whoops, or just read what Dan wrote, haha! (I didn't hit refresh)
DanPatterson_Retired
NigelBerjak
Hi Dan and Adrian
Thanks. It then appears this is a 'glitch' to workaround the legend transparency issue. Good to know and hopefully someone else will find it useful as well.
Cheers,
Nigel
KFAgis1
Using or not using layer transparency in the legend was a simple toggle in ArcGIS. Is there any new info on this topic? I generally never simulate layer transparency in my legends (in Desktop), so not having an option in Pro seems like, yet again, a major oversight (there are so many of these!). I'm really forcing myself to use Pro for exhibit production lately but the UX is pretty lacking. I'm constantly having to toggle things on and off to get to the desired options, you have to find complicated work-arounds for things that used to be built in. . . it still seems like a there are major steps backward with Pro. Increased familiarity with the program isn't necessarily helping either- it's just kinda reinforcing this for me. Most of my internet searches just turn up results from other long-time users complaining about the same things.
NigelBerjak
Do we have any update on this request from ESRI as yet, as to when it may be employed or a workaround?
SpatialSam
Hey Nigel,
I found a workaround, depending on what you are looking for. I have a partially transparent layer in my map, and I didn't want the symbol/patch to be transparent in my legend.
If you convert the legend items to a graphics layer, you can select the patch, copy it, and then paste it over itself. This will create the illusion that it is not actually transparent.  Another option would just be creating a polygon/point/line and replicating the symbology.
