ArcPro Feature Class Join
2239
9
02-26-2021 12:26 PM
MatthewMendes
Hello, I am switching from arcmap to arcgis pro and I have a question. regarding ArcPro Feature Class Join, I need to know if there are instructions for a Unique join between features. Tables don’t have an x,y. I need a unique join between feature classes such that once a record is joined once, it can’t be joined again. Preferably with a field indicating the distance between the two. It’s either a fairly simple Arcpro thing or you can’t do it
DavidPike
MVP Notable Contributor
Can you elaborate a bit more - table join based on same field values, or by proximity or both? One to one.. etc?  Also on what 'can't be joined again' entails - as in joining the feature to any other table at a later stage would not be possible?
MatthewMendes
where Spatial Joins are based on proximity a join based on a matching attribute is simple. For example Transformers and Consumers.  Using Transformers as the "base" feature and Consumers as the feature being joined to the transformers. A basic spatial join will leave you with all your transformers, and each transformer will have the nearest consumer joined to it. However, if the same consumer is 10 feet from one tran and 100 feed from the next tran, but the next nearest consumer is 500 feet from both, then the same consumer will be joined to both transformers. That's base ArcMap functionality, but what I need is the consumer that's 10 foot from a transformer to be joined to that transformer, then it can no longer be joined to any transformer, and then we keep joining until all the transformers have a consumer joined (or we run out of consumers)
DavidPike
How about spatial joining the transformers to the consumers?
target_features = consumers
join_features = transformers
match_option = CLOSEST
JoeBorgione
How did you do it in ArcMap?
That should just about do it....
DanPatterson
MVP Esteemed Contributor
Since you have no coordinates in your join table, spatial join is out and that leaves you with
Join Field (Data Management)—ArcGIS Pro | Documentation
Add Join (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
JoeBorgione
I've done a few joins in my career; spatial and tabular.  I think I did my first in 1990 with ArcInfo, but thanks for the explanation on how they work none the less..
DanPatterson
replying to the OP @JoeBorgione ... but bookmark it just in case 😉
JoeBorgione
I was replying to the OP too...
DanPatterson
great minds think alike!!!
