ARCPRO 3.0 Crashing
3265
02-23-2023 06:22 AM
stevebrooks1
Switched to ARCPRO 3.0 at work and have found that it crashes for no apparent reason. We use a lot of imagery at work and having Pro crash during a project is getting infuriating.  Is there any way that I can establish why it is crashing (a fault log for example) so that I can go to my database manager to try to rectify this?
2 Solutions
SLouq
by MVP Alum
I have ArcGIS Pro 3.0.1 and use mosaics created from raster datasets as a base map and mine works fine. How is your imagery hosted?
For example is it hosted in a file geodatabase? Or a network server?
SLouq
by MVP Alum
if possible try uploading the imagery to a file geodatabase and see if that helps. It could be the way you are accessing the imagery causing it to crash.
SLouq
by MVP Alum
stevebrooks1
Apologies for not being clearer. The imagery we use is on a server. We have not changed the way we work and everything was fine with version 2.8. I cannot tie the reason down to one specific example as to what i am doing when it decides that it has had enough and quits on me.
SLouq
by MVP Alum
George_Thompson
Esri Notable Contributor
Can you provide more context and details as @SLouq mentions?
--- George T.
