Arcade Identify Text in one field to change another field
1644
02-22-2023 03:03 PM
LeviCecil
I have a bus stops point dataset. There is a field called "IsBusStop" and every single point is set to Y. The problem is, some of the points are actually loading zones, not bus stops. There is a point description field which includes "LOADING ZONE" for those points. I need to find that text, and then change IsBusStop to N. I'm trying to use the Find() function, but it's not working. I need something along the lines of "LIKE" in SQL.
Here is my expression so far:
var description = $feature.PointDescription
var busstop = $feature.IsBusStop
var lz = Find('LOADING ZONE',description)
When(lz == 1, Replace(busstop, 'Y', 'N'),busstop )
LeviCecil
Thanks for this, but I need to change the IsBusStop field based on whether or not "LOADING ZONE" is found in the description field.
I just figured it out.
var loadingzone = Find('LOADING ZONE',description)
var lz = Find('LZ',description)
When(loadingzone > 0 || lz > 0, Replace(busstop, 'Y', 'N'),busstop)
JohannesLindner
IIf(lz == -1, 'Y', 'N') // 'LOADING ZONE' not found -> 'Y'
You could also replace 'LOADING ZONE' and check if the description has changed:
var repl_description = Replace(description, 'LOADING ZONE', '')
IIf(repl_description == description, 'Y', 'N' )
Have a great day!
Johannes
LeviCecil
JohannesLindner
Yes, but if the IsBusStop field can only have the values "Y" and "N", then you don't actually need to replace that value, you can just set it.
That's because you use another expression. Try it with the expression that actually worked.
Have a great day!
Johannes
