ARCMAP to ARCGIS PRO - STYLES IMPORT
3802
03-15-2024 03:04 PM
nimitz
Hello all,
I'm slowly migrating to ArcGIS Pro. I'm trying to save all my symbology to a style that I can then import into ArcGIS PRO. I have a lot of symbols.
It seems like the only way to do this is to INDIVIDUALLY save each symbol into my personal style and then import the style into ArcGIS Pro. Is there a way to save ALL of the symbols I've created in this .mxd? It's very tedious so far.
KoryKramer
Esri Esteemed Contributor
Have you tried Customize >  Commands > Export Map Styles...
RhettZufelt
MVP Notable Contributor
In ArcMap you can go to 'Customize', Style Manager, select the symbols/text/etc. that you want to keep, copy and paste them into a new/existing style.  Then you can import that single style file in Pro.
R_
