ArcGIS Python Reclassify Coding Problem-Stop Iteration
431
05-04-2026 05:53 AM
Leeyak88
Good morning, All
I have an assignment. We will classify watersheds based on the area to perimeter ratio in the huc4.shp shapefile.
In the Contents, right-click the huc4 layer and click Attribute Table. Review the fields of watersheds. Notice that there is a field called SHAPE_Area and a field called SHAPE_Leng.
Task: Write a script in Python that will determine the Class of each polygon by calculating the area to length ratio and grouping into a Class accordingly to the table below. In ArcMap, create a map assigning symbology to the Class as follows.
Area/length Ratio
Class
Symbology
Ratio > 40,000
Low
Green
20,000 < Ratio <= 40,000
Medium
Brown
15,000 < Ratio <= to 20,000
High
Orange
Ratio <= 15,000
Very High
Red
I wrote a python script. However, it occurs an error ' Stop Iteration'. How to fix it?
Appreciate the solutions.
DanPatterson
MVP Esteemed Contributor
your last 3 lines need to be indented 4 spaces so that they are within the cursor loop
... sort of retired...
