ArcGIS Pro vector tile package: line feature labels from multiple label classes are not distinguished correctly
368
06-25-2026 08:12 PM
bondxiao
I’m creating a vector tile package (`.vtpk`) in ArcGIS Pro for a line feature layer. According to the official documentation, when a feature layer has multiple label classes, the exported vector tiles should distinguish them using fields like `_name`, `_name1`, etc.
Official documentation:
https://pro.arcgis.com/zh-cn/pro-app/latest/help/mapping/map-authoring/labeling-in-vector-tiles.htm
However, in my case, when I publish/export line feature labels to a vector tile package, all label classes are written as `_name` in the generated vector tile style JSON. I cannot use `text-field` to distinguish different label classes, because the expected `_name1`, `_name2`, etc. fields are not generated for the line features.
Example of the generated style JSON:
```json
"id": "pipelineline",
"type": "line",
"source": "esri",
"source-layer": "pipelineline",
"layout": {
"line-cap": "round",
"line-join": "round"
"paint": {
"line-color": "#3C8C46",
"line-width": 1.33333
"id": "pipelineline/label/类 2",
"type": "symbol",
"source": "esri",
"source-layer": "pipelineline/label",
"filter": [
"_label_class",
"layout": {
"symbol-placement": "line",
"symbol-spacing": 1000,
"text-font": [
"宋体 常规"
"text-size": 13.3333,
"text-anchor": "bottom",
"text-offset": [
0,
-0.1
"text-field": "{_name}",
"text-optional": true
"paint": {}
"id": "pipelineline/label/类 1",
"type": "symbol",
"source": "esri",
"filter": [
"_label_class",
"layout": {
"text-font": [
"宋体 常规"
"text-offset": [
0,
-0.1
"paint": {}
Problem:
- The line features have multiple label classes in ArcGIS Pro.
- After exporting to a vector tile package, all labels are mapped to `_name`.
- The expected fields `_name1`, `_name2`, etc. are not generated for the line labels.
- As a result, I cannot distinguish label classes using `text-field` in the vector tile style.
Question:
- Is this a known limitation for line features in vector tile packages?
- Is there any supported way to preserve multiple label classes for line features?
- Should I split the labels into separate layers before exporting?
- Is there a workaround to make ArcGIS Pro export `_name1`, `_name2`, etc. for line labels?
Any guidance or official workaround would be appreciated.
