Hello. I created a blank template with connection to my agency's sde gdb. The template opens in ArcGIS Pro Basic, the db connection is there, and I'm able to see and add feature from it to my map. However, opening the same template using ArcGIS Pro Advanced doesn't allow me to open the db connection at all. Do I have to create two templates - one for Advanced users and one for Basic?
I can't find anything specific here... http://pro.arcgis.com/en/pro-app/help/projects/create-your-own-project-template.htm
but did you run an analyse and got no warnings? http://pro.arcgis.com/en/pro-app/help/sharing/overview/analyze-your-gis-resource.htm
Is this on the same machine (just changing the license level)? If not, there might be differences in the installed software on both machines, like for instance the 64 bits Oracle client if your sde is pointing to an Oracle EGDB.
Yes. Same machine, just changing licensing level. Odd.
Jennie - the license level doesn't have anything to do with creating projects from templates. Just to check for a bug, I added an SDE database (but SQL not Oracle) to a blank project, saved it as a project template, and was able to create a project from that template using a Pro Advanced license.
So there could be something specific to Oracle. If you're still experiencing the behavior, please open a case with technical support to troubleshoot further.
Thank you!
