ArcGIS Pro system requirements
10630
05-21-2024 01:54 PM
Labels (3)
ChrisStover
Howdy.  I am getting close to leaving governmental life….and am looking to purchase a laptop for running Pro.  I am relatively savvy with system hardware; I have seen the system requirements…. But not that savvy.  Could someone tell me the adequacy of this system?  Or would you have a recommendation?
thanks in advance.
chris
DanPatterson
MVP Esteemed Contributor
you can do the matchup with the spec here
ArcGIS Pro 3.3 system requirements—ArcGIS Pro | Documentation
... sort of retired...
ChrisStover
My posted specs pretty much line up with that document.  I am really curious about the graphics.  Do my posted specs get me there?  Only planning on running the basic Pro.
DanPatterson
Dedicated (not shared) graphics memory
Recommended: 4 GB or more
If you're using a notebook computer with an integrated GPU, consider increasing the system RAM to compensate for the use of shared memory.
If you aren't planning to do much deep learning (as compared to shallow learning), and for Pro basic, it should be fine.  For everything else that you would use  computer for, it should more than suffice.
