Arcgis Pro - Sync Create a version for each user
3122
8
07-31-2020 07:55 AM
RickeyFight
Is there a way in arcgis pro when creating a service to enable creating a version for each user?
Here is what the desktops options are:
JonahLay
Hi Rickey,
Great question! We added this functionality in ArcGIS Pro 2.6 which was just released. For more information. please see the following topic (step 12): Configure a web feature layer
Best,
Jonah
RickeyFight
Jonah Lay
Thanks for the information. I have updated to 2.6 and did not see the option. I believe this is because I have 10.6.1 not 10.8
JonahLay
Yes, you are right. Sync Options are not available when you are sharing to ArcGIS Enterprise 10.8 and earlier.
RickeyFight
Jonah Lay
So my work around is to publish in pro. Then I go to ArcCatalog and change the service.
ahargreaves_FW
@JonahLay  I'm using Pro v2.9.2 and a 10.9.1 portal but despite configuring my Feature Service to have Sync Enabled I am unable to select 'Create a version for each user' when attempting to publish my data as a vector tile referencing registered data (as shown below)
JonahLay
@ahargreaves_FW Thanks for reporting this. This does look like a bug that should be fixed in a future release.
ahargreaves_FW
@JonahLay is there a BUG number to track this? Or do you need me to open a support case to report this bug?
JonahLay
@ahargreaves_FW Our teams are aware of this issue. But if you would like to track progress, yes, feel free to open a support case.
