ArcGIS Pro - Symbology Multiple Fields - Classes Disappear and Can't Be Added
352
07-10-2024 09:37 AM
tiztrain
Hey all,
Having an issue that when I add another field to the symbolisation, all the classes disappear and I can't add any. Same problem occurs when using custom expressions.
tiztrain_0-1720629126285.png -->
Does the dataset have to contain data?
Robert_LeClair
Esri Notable Contributor
Ah I understand.  So yes, the feature class must contain data for the add all values to work.  If there's no data in the layer, the process will not work.
Robert_LeClair
Testing this on my ArcGIS Pro and this appears to be expected behavior when you add a new field to the Unique Symbology item.  I'd recommend you add both fields first, then create the symbology second.  That way it doesn't remove the formatting.
tiztrain
@Robert_LeClair when I do that and then click the 'add all values' button, nothing loads in.
Is the only way to add the values is to manually add them all?
The 'add all values' button worked for me previously, the only difference was that it was an older version of Pro and the dataset contained data.
Robert_LeClair
tiztrain
Yep ok so it is standard behaviour. Would be nice if it would work with no data and building the new dataset.
