ArcGIS Pro signs me out from AGOL
3389
7
10-30-2017 10:39 AM
DavidColey
MVP Frequent Contributor
Hi -
Does anyone know why Pro 2.0.1 would drop my signed-in status to our AGOL org?  Is there a time-out setting somewhere?  The way I am staging and uploading hosted content relies on my being signed into our AGOL account:
arcpy.mp.CreateWebLayerSDDraft(lyr, "V:/ArcProProjets/AgolUpdates/Cadastral/" + lyr.name + ".sddraft", lyr.name, "MY_HOSTED_SERVICES", "FEATURE_ACCESS",
 "OpenData", True, False, False, True, False, "", 'Cadastral')
 arcpy.StageService_server('V:/ArcProProjets/AgolUpdates/Cadastral/' + lyr.name + '.sddraft', 'V:/ArcProProjets/AgolUpdates/Cadastral/' + lyr.name + '.sd')
I'm running this once a week on Saturdays.  I should note that we are using our concurrent license manager and not named user accounts.
David
DavidColey
So interesting note on this with the 2.1 update.  The new arcpy.SignInToPortal arcpy function does work, but if you want to upload the service definition it looks like you need to do so in the same try block that you create the sddraft and stage the service.  I have tried using the sign-in with just the UploadServiceDefinition function in a stand alone bloc and it does not work, returns an 'not signed in error'.  But if you run everything together seems to work ok:
try:
      # Sign-in to ArcGIS Online
      arcpy.SignInToPortal("https://yourorg.maps.arcgis.com/", "your_username", "your_password")
      print ("I'm signed in")
      portal = arcpy.GetActivePortalURL()
      print (portal)
      aprx = arcpy.mp.ArcGISProject(r'V:\ArcProProjets\AgolUpdates\AgolUpdates.aprx')
      for m in aprx.listMaps("HostedAppLayers"):
             message = message + "\n\n" "Map: " + m.name + "\n\n"
             print("Map: " + m.name)
             for lyr in m.listLayers():
             if lyr.name == 'ParcelsHosted':# or lyr.name == 'ElevationCertificate':
                   print(" " + lyr.name)
                   arcpy.mp.CreateWebLayerSDDraft(lyr, "V:/ArcProProjets/AgolUpdates/HostedAppLayers/" + lyr.name + ".sddraft", lyr.name, "MY_HOSTED_SERVICES", "FEATURE_ACCESS",
                         "HostedAppLayers", True, False, False, True, False, "", 'HostedAppLayer')
                   arcpy.StageService_server('V:/ArcProProjets/AgolUpdates/HostedAppLayers/' + lyr.name + '.sddraft', 'V:/ArcProProjets/AgolUpdates/HostedAppLayers/' + lyr.name + '.sd')
                   message = message + "\n" "Layer: " + lyr.name
                   arcpy.UploadServiceDefinition_server('V:/ArcProProjets/AgolUpdates/HostedAppLayers/' + lyr.name + '.sd','My Hosted Services', "","","","","",
                          "OVERRIDE_DEFINITION","SHARE_ONLINE","PUBLIC","SHARE_ORGANIZATION","")
except Exception:
       # If an error occurred, print line number and error message
       import traceback, sys
       tb = sys.exc_info()[2]
       e = sys.exc_info()[1]
       #print(e.args[0])
       #print "Line %i" % tb.tb_lineno
       message = message + "\n" + "Line %i" % tb.tb_lineno
       message = message + "\n" + e.message‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
EricPeña
I had the same issue happen to me last week, where my Pro sign-in settings seem to have reset and my script for overwriting a web layer stopped working (since I wasn't signed in anymore).
I suspect it was an automatic update that caused it to sign out, so I've unchecked "Check for updates on startup" in the About ArcGIS Pro section.  If this works, I'll just update Pro and log back in on my schedule.
We'll see if it happens again.
DavidColey
Thanks Eric, I'll give that a shot as well.  Feels buggy.  It'd be nice when ESRI adds the Sign In To Portal Sign Out From Portal tools to the 3.x python . . .
DavidColey
Actually, scratch my last.  I did not and do not have the 'Check for updates on start up' option selected, so I don't know . . . seems that there is something that checks for inactivity or something in AGOL
EricPeña
There goes my theory... Thanks for letting me know.
DavidColey
sure if I find out anything I'll post back
DavidColey
Still no update on this.  Does anyone know if Sign In To Portal / Sign Out From Portal will be included in the next or future release of ArcGIS Pro?
DavidColey
try:
      print (portal)
except Exception:
       #print(e.args[0])
