ArcGIS Pro Reports
310
02-04-2026 11:12 AM
Joel
I am new to using the Report function in ArcGIS Pro 3.6.1
How do you make a multiple page report? I need to show information for each record, but each record contains more information than will fit on a single page.
I used the Page per Feature from the default ESRI template list.
I ran out of space as I added more items to the report. Eventually I got this message: "an element is larger than the available page space".
I resized my Details section and was able to export. I must have done something else when I did this because my export added a blank page after each full page.
This seems like a simple, basic detail but I have not found any information in my searching.
Does 'Page per Feature' mean only one page per feature?
I will try a different template next.
Robert_LeClair
Esri Esteemed Contributor
To be honest, I have not worked with reports at all but found this tutorial to be very helpful in creating a multiple page report - Tutorial: Create and modify a report—ArcGIS Pro | Documentation - perhaps it will help you troubleshoot your report.
