ArcGIS Pro Rendering Problems
1081
11-10-2022 04:48 AM
CHRISTSALLIS
Greetings,
I am using ArcGIS Pro and I am facing a problem with rendering. As you can see I have an image from Landsat which is not loading when I want to edit it. So, I am describing bellow (with images) my problem.
-The map that you see behind on each image is the World Topographic Map and has nothing to do with my main images.
Thank you for your time, appreciate your help.
When I start my project the following image appears, which is fine.
After that, when I am trying to change the date from my image this happens.
CHRISTSALLIS_1-1668084435636.pngCHRISTSALLIS_2-1668084441971.pngCHRISTSALLIS_3-1668084450325.png
And in the end when I tick or untick again everything this happens (see bellow images).
CHRISTSALLIS_4-1668084463096.pngCHRISTSALLIS_5-1668084471889.pngCHRISTSALLIS_6-1668084480073.png
Is this a problem caused by my computer, or is it a software problem?
Thank you again for your time.
RobertBorchert
Honored Contributor
Are you using Web Mercator for your projection>:?
CHRISTSALLIS
Hello,
I am not sure what that means, but I am using Projected Coordinate SystemUTMWGS 1984, and Southern Hemisphere. May you please explain me more what Web Mercator is?
Thank you.
