create attribute rules to copy a field value from intersecting polygon
3029
11-09-2022 12:12 PM
kazzie
I'm trying to create an arcade intersect expression for attribute rule in arcgis pro which will populate the attribute field 'Habitat_SiteName' in my Habitat_Patches layer when I create new polygons. The underlying polygon field name in the Habitat_Polygons layer is 'SiteName', within a file geodatabase.
Feature class 1: Habitat_Patches
Feature class 2: Habitat_Polygons
Triggers I would like to use are Insert and update.
2 Solutions
JohannesLindner
// load the habitat polygons
var habitats = FeaturesetByName($datastore, "Habitat_Polygons")
// get the first intersecting habitat
var habitat = First(Intersects(habitats, $feature))
// no intersecting habitat? -> abort
if(habitat == null) { return null }
// else return the habitat's site name
return habitat.SiteName
Have a great day!
Johannes
JohannesLindner
 In that case, you would leave the field parameter empty and return a dictionary instead of a value.
return {
    "result": { "attributes": {
        "Field1": habitat.Field1,
        "Field2": habitat.Field2
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
kazzie
Thanks Johannes, that worked a treat. sorry another question im trying to get my head around arcade. How would it work if you had multiple fields to copy.
JohannesLindner
return {
Have a great day!
Johannes
kazzie
Thanks again Johannes, the link was really helpful and will have a play with the other options.
Have a great day too
Kazzie
