ArcGIS Pro - Quality tab
1965
12-09-2024 07:36 AM
AnthonyKiely1
Hi all,
I need to do some quality control on some polygons within ArcGIS Pro 3.3.0 but the Quality tab is missing from the nav bar at the top. Has these happened anyone else?
Any ideas?
Thanks
Anthony
Robert_LeClair
Esri Esteemed Contributor
Check to see if you have the Data Reviewer extension licensed.  If not, then this may explain why the tab is missing.
Robert_LeClair
AnthonyKiely1
Thanks a lot, Robert.
Yep, I am not licenced for the Data Reviewer extension which is causing the issue.
Thank you
