ArcGIS Pro Python
1181
03-16-2020 10:33 PM
KalSsin
Hi~~~
How do you select multiple fields?
Only one field is selected.
I'd like to select three as shown in the picture.
DanPatterson_Retired
from the command line, you have to type in the field names, there is no multi-select capabilities
JoshuaBixby
MVP Esteemed Contributor
If you want to use a GUI to select multiple fields, just run the geoprocessing tool and use the dialog window that allows multiple field selection:
DrewFlater
Multiple field names can be given in a Python list:
["FIeldA", "FieldB", "FieldC"]
