ArcGIS Pro points from export file fail geometry test
1939
03-02-2021 02:02 AM
John_Hynes
Have a working centroids table which plots. Exported the centroids XY to Excel and created a new and different CSV file using the centroid XY longitude and latitude. Then used Geoprocessing "XY table to point" tool to create new table and all table entries rejected. Errors 100160 and 000192.
DanPatterson
MVP Esteemed Contributor
000192: Invalid value for <value>.—ArcGIS Pro | Documentation
What does the table look like?
... sort of retired...
John_Hynes
table has headings but all rows rejected
DanPatterson
The Excel file? It sounds like something went wrong at that step, eg. non-numeric entries, csv issues
JayantaPoddar
Could you share a sample of the XLS and CSV files for us to have a look at?
Think Location
John_Hynes
The problem seems to be with the XY of the centroids. These were in WEB Mercator or UTM. IRENET95 is in UTM zone 29. When I converted the centroid XY to Latitude and Longitude the Latitude was off 10 degrees and the longitude off 1/2 degrees. So the centroid values were not valid.
