Hi folks. Anyone have any luck getting polygon labels to work in ArcGIS Pro like they do in ArcMap? In Map I often make use of the "Place label at fixed position within polygon" option, where if the polygon centre isn't visible the polygon just doesn't get a label. This is perfect for land sections, as they look much neater with just labels in their centres. In Pro, even with this option check and all internal zones other than centres set to 0 (blocked), the labels still squeeze their way in. Image below showing what I mean, with ArcMap looking the way I'd like and ArcGIS Pro not so much. I know I could turn these into annotations and delete the ones I don't want, but the automated option is much better if the project area changes a bit. Any thoughts? I do have Maplex enabled.
