ArcGIS Pro not seeing correct SDE version
801
02-08-2019 08:32 AM
DeanRother
ArcGIS Pro is not seeing the correct default version of my data, but ArcMap is. Has anyone seen this and have a recommendation?
JoshuaBixby
MVP Esteemed Contributor
There really isn't much to go on here.  What versions of ArcMap and ArcGIS Pro?  What platform and versions for the enterprise geodatabase, e.g., SQL Server 2012 and ArcGIS 10.5.1 geodatabase?
I assume you are using the same database connection file, but it is good to state it explicitly.  What are the connection properties of the database connection file, both database and geodatabase properties?
